RE: Evolution 46 HELP!!!
G'day Mate,
When you lift the nose up, at full throttle, if it is rich enough, the engine should pick up some revs, if it does it's ok to fly, if not, richen HS mixture until it does gain some revs, when nose lifted.
No reason not to change glow plug, if in doubt. they are cheaper than a new plane if the engine cuts, just after take off.
