Two Elevator Servos
Hi guys,
I'm setting up a plane that has two elevator servos mounted to the sides of the fuselage. I have a Futaba 7 CAP and I understand that this paticular radio does not have a dual elevator feature. Also, as you guys know, if I mix two elevator servos together then when I use the trim, only one elevator servo moves. Can I use a regular y-harness or will I need a reversing y-harness? Just to clarify, one servo is mounted on one side of the fuse and another on the other side. Both servo arms point down.
