ORIGINAL: 46u
Make sure you put the piston at BDC while cooling between cycles. How hot does a hair dryer get the engine when preheating? I use a heat gun and get my engine up to at least 190 degrees before starting while breaking in. Keep us posted.
Thanks, I did put the piston at BDC.
My GF's hair dryer is 1875 watts, so it was able to get the engine to about 190, I just had to leave it on there for a bit longer than a real heat gun.
I can usually tune, but I did not turn down the help of a 15 year veteran sponsored driver, for it's first tune. He still tuned it rich, and said to start leaning for performance after another 1/2 gallon.
This STS motor is actually in my 8-T, but I started with the Mach427 engine that I stole from my rtr buggy. To be honest, my Fioroni clutch is engaging way to soon, there for I have no low end punch. Needless to say with I was not impressed, but I did not expect the .21 to have the low end of .28. I will get new shoes and harder springs and try her out again.
