RE: E-Flight Extra 260 with showstopper VPP
I have the same plane and i agree with hellblastervolly, but htat particular setup is not the best for backwards flying. You will have to play with the pitch and throttle curve a lot to get it there, and be careful because when you ge too much pitch, yes i said when, coupled with too much throttle you will probally snap the plane in the air. I DONT mean snap roll, i mean snap the wing off at the outer supports. getting that much pitch and throttle is murder on the airframe, so go in small stepps/
