10x - Throttle Curve Expo?
I am trying to get a curve on my 40% gasser.
What exactly is the expo for on the curve, and what does it do?
It didn't seem to make any difference in engine performance when switched from off to on.
Also, the curve allows 5 points.
What's the best way to get more resolution within those points?
In other words, once I set points 1 and 2 on the low end of the throttle stick, I can move
3 to 4 clicks without any throttle movement because of the way it works.
Once you set the point, you can't get any more travel on the servo until you hit the next
point which is unusually far away.
Is there a way to use an 8 point mix for throttle and get more control over the curve?
Bob
