RCU Forums - View Single Post - Evolution 46 HELP!!!
Old 08-06-2007 | 09:18 AM
blw's Avatar
blw
Default RE: Evolution 46 HELP!!!
How old is the .46NT? Was this the original plug that came with the engine?
Mine always runs great. Peak your highspeed needle valve and then back off at least 300 RPM. Also, I would suggest trying an OS A3 plug in this particular engine. Some people will tell you that the OS 8 is the perfect plug, but it isn't for most Evolution engines. They like hotter plugs. You may find it solves your issues and gains quite a bit more power. I haven't tried the A3 yet because a friend gave me a few of the older type of Tower's plugs. I'll go to the A3 when those are gone. I ran the Evo .455 with a Saito SS plug, but I didn't see as good of an improvement as with those older plugs. The newer Tower's plugs seem to be colder and not much of an improvement, and is the same as the Saito plugs.
If you rebuild, check the tank and lines like Biged suggested.
