RCU Forums - View Single Post - anyone building a king kobra?
Old 08-06-2007 | 10:04 AM
NM2K
My Feedback: (14)
Default RE: anyone building a king kobra?
I wish one of you "honeycomb" fans would weigh all of the pieces of foam that you have removed from the wing and report the weight here. I doubt there is a 1/2 ounce of foam to be measured. Yes, the glue not glueing those sections "could" decrease the weight some, if you put the glue on the honeycomb and not on the wing skins. I've never understood the fascination with this technique, especially after seeing more than a couple wing failures because the honeycomb process weakened the structure to the failure point.
I'm not trying to start a fight, just a discussion. No offense intended.
Ed Cregger
