RE: Top Flite Cessna 310 posted
Tim,
It very important that you ordered the "e" type props. The standard apc will do you no good. The camber at the root of the "e" props and the taper is what makes these efficient. You will see that this is not the case with conventional props. So dialing in the diaxpitch only, will not give you the right numbers. Are you using Motocalc?
