RCU Forums - View Single Post - Low compression when hot
Old 08-06-2007 | 02:28 PM
littlekicker
Default RE: Low compression when hot
Hi, Yes it still runs ok, but requires an electric starter to start it when hot.
I thought the ABC engines were designed in such a way that the piston and cylinder expanded at the same rate to maintain the fit at running temperatures? Is this not the case?
Regards Angus
