CAP232CM
It sounds like your putting everything on in the right order not really sure what the problem is.
The problem i'm having is the pin pattern on the backing plate. Theres 2 pins and 2 screw pins. The prop is supposed to sit untop of the 2 pins and the 2 screw pins are supposed to be verticalo of teh prop. Well if i put the prop where it's supposed to go then the 2 screw pins wont align with the spinner. Confused you more? It's hard to explain sorry. Thanks for all the other brake in tips and Good Luck with your Terry. I Love mine and also have a ton of video of it. Email me at
[email protected] if you would like some video clips of it.
tsawyer148 thanks for the heads up on the spinner. I live on an AF Base in Japan so no LHS for me. I have to order everything
I'll have to try and make it work. If you could send a picture that would be great:
[email protected]
Also did you have any trouble with breaking in your engine? Did you use starting equipment or just try and crank it by hand? I try it with a starter but it's like the starter doesn't have enough power to turn it. I have a High Tourq 1 so i'm not sure what the trouble is.
Thanks Again for the tips fellas
