US 41 won't run
Sounds a lot like the problem I just had with a Homelite 25 I converted. I put the carb on the wrong way so the little hole in the carb base to the pump was on the wrong side. No crankcase pressure to the pump. No start. The carb looks like it has two holes in it, but one is just a blind hole. Worth a look before tearing down the carb.
Steve
