RCU Forums - View Single Post - Two Elevator Servos
Old 08-06-2007 | 04:55 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Two Elevator Servos
ORIGINAL: Ferocious Frankie
Will I still have the same problem? I pretty much already emptied my pocket so I don't know about the matchbox.
Yes you will still have the same problem that unit will not fix your problem it does not reverse just one of the servo's.
If you have an ordinary 'Y' chord------You Do Not Have to Spend Money------
Reread Post #3
Use the ordinary Y chord on both elevator servos that stick outside the fuselage. Install one servo horn sticking straight up. Install the servo horn on the opposite side of the fuselage sticking straight down now just hook the pushrods up, one side goes just above the servo and the one on the other side side of the fuselages goes just below the servo.
Both pushrods will go to horns below the elevator halves .
You are done. Everything is fine, trims work properly and your Tx reversing switch will work normally.
John
