RCU Forums - View Single Post - Spektrum DX6 Setup
Old 08-06-2007 | 08:51 PM
darnoff
Default RE: Spektrum DX6 Setup
Thanks for your comments. The setup file you attached will be a guide for my next setup, thanks a lot.
I have already installed my Spektrum Radio on Falcon 3D, I have replaced the stock receiver and leaving the same servos for now.
I have tried several changes in the Throttle and Pitch curves, I have realized there are huge changes on the heli behavior depending the % number I setup on the radio.
The same bird goes from uncontrolled mad heli to a quiet butterfly flying in front on my nose...only changing the pith numbers. It was a great experience!
Now I am gona try the settings you suggest on Dual rate and Exponencial...after that I will publish my own setup here for share.
Thanks again and best regards
daniel
