RE: engine vooo doo
If its not the tank. ANd its not the carb. Then I still feel its the bearings. Is there another carb that you can bolt on ? Bad bearings will typically run OK for about 3 or 4 minutes, then the case heats up and the timing goes bad. How long did you say it runs ?
