ORIGINAL: PilotFighter
If its not the tank. ANd its not the carb. Then I still feel its the bearings. Is there another carb that you can bolt on ? Bad bearings will typically run OK for about 3 or 4 minutes, then the case heats up and the timing goes bad. How long did you say it runs ?
thanks Ill recheck the tanks and lines , right now when it was on the bench the other day after about a 30 second or more of full throttle then it would die
