ORIGINAL: splais
mounting your servos out by the control surface. I think the general consensus is that tip mounted servos are much superior to that pushrod and bellcrank setup in the plans.
Absolutely!
In my PUP each aileron even has its own servo, though it is enough having a strong one in the lower wing with a push rod to the upper,
Frank
