RCU Forums - View Single Post - new to sailboating.
Old 08-07-2007 | 04:37 AM
mfr02
Default RE: new to sailboating.
If the servo is failing to pull in against the wind, the trick is to steer into the wind, thus reducing the load, and then pull in. If the boat is carrying too much sail for the conditions, no amount of extra power is going to solve the problem. On the other hand, setting the sails correctly lets you sail in stronger winds than would be the case otherwise.
