RCU Forums - View Single Post - Two Elevator Servos
Old 08-07-2007 | 11:36 AM
opjose's Avatar
opjose
Default RE: Two Elevator Servos
ORIGINAL: wavy777
Frankie,
Hope i didnt confuse you too much, bad mouthing the inline reversers. They work, but just keep an eye on the centering of the servo, it will move. Make sure you have easy access to the reverser, so you can adjust the centering of the servo when you have to (they have a potentiometer which can be adjusted by a small screwdriver, which moves the center position of the reversed servo).
Yup exactly.
You may find that you have to adjust the reverse each time you go out to the field.
The occillator crystals used vary with temperature, causing the centering to be off constantly as conditions change.
