RE: Combat plane stands
Yeah, but foam tends to get fuel soaked pretty quickly, and starting stands tend to take a beating. But foam should work.
And yes, they don't have to be high, but it is generally easier on you to have a stand that holds the plane up higher. A lot of guys build stands to hold the plane at waiste level, though mine is a low stand because I'm still young enough to use it comfortably.
