RE: axe cp thread
If your LHS only stocks gobs of parts for the BladeCP, you can opt to use the rotor blades for that on the AxeCP. They are a direct fit once you remove one of the black caps that cover the lag bolt hole. They are a bit shorter and this will increase your headspeed a bit. But they work.
