ORIGINAL: dsnyder
If the light is flashing it is going into bind mode, which it should only do with the bind plug installed. Do you have the bind plug installed? There is no need to rebind after you have bound the receiver and set all of your failsafe positions as desired.
The RX will not reinitialize when the power is cycled. If I wait 10 minutes with the power off then turn it on the RX/TX work fine. IF I shut off the RX and try to turn it on again it will not work.The satelite RX continues to flash, the main RX light goes solid. No bind plug installed. I can BInd etc as long as I wait between power ups.
My 3 other RX's don't do this.
