Hi Guys, need some advice from ya's if you will.
I building a GWS 262 (the brushless version) Looking to get the best performance I can get out of what I have here.
SO, I'm at the stage of installing motors, I have installed Cobri 300 shims on the motors from E-Flightline (
http://www.e-flightline.com/) very nice bushings by the way - perfect fit in the fan housing, also installed E-Flite heatsinks on motors, the shroud and fan is stock GWS.
Now, the question is - "How do I balance these fans to run true?"
I installed the shaft adapter into the fan then slipped on motor shaft, spun fan and I'm getting a very noticeable wobble?[X(] everything seems to be tight, but definitly not good.
Should I be buying better fans or adapters for the fans?? if so please tell me were I can purchase or please tell me what I'm doing wrong.
Thanks in advance for you help!!
BOY!! There's some very fast GWS 262's on video that YOU guys are puttin out, AWSOME job guys!!
please share some of your secretes with us 262 fans, all tips and advice WELCOME!!
willey
