electric?.. very interesting.. what was your duration and how many mah did it take to recharge the batteries?
Zinger props are a waste of time in electrics.. any kind of APC will be nice, sport or electric (except slow fly props).. if you want a wood prop try the master airscrew series, Tower sells them.. rework them a bit, sharpen the trailing edge, smooth out the leading edge then thin down the airfoil shape a bit.. then rebalance carefully. Just as efficient as APC but much less prop noise at the 1000watt level.
Zingers are good if you rework them, good starting stock but lots of sanding dust.
Do you think 1000watts per side is enough?
Herm
ORIGINAL: timothy thompson
flew tonight with one zinger 15x8 and one apc 15x8 best flight to date nice and fast no yaw issues . I might have a bipolar 310!!!
i will put two zingers on and paint the flat black with yellow tips for the scale look or maybei should leave it alone
BTW shes electric
