RE: Rotary carb question
Had a simliar experiance with a rotary carb and took it apart to remove the spring. The cylinder operates by moving the barrel up and down while rotating to control the gas flow on a stationary needle valve. The whole ordeal turned into a disaster. Now looking for a way of replacing the carb with a different type of carb. You might consider getting a hi torque servo instead.
