RE: OFFICIAL WHEELY KING CRAWLER THREAD
Woot! A wheelie king thread!
I lengthened mine with collars and extended bars, lengthened main servo bar and used brass tubing cut into rings to tighten the shock caps and pevent them from stripping out. Also had to use after market drive lines as the stock ones were too short.
Also had to replace the motor and speed controller. First update was a better 300 ma battery and prophet charger. everything else cam later. Still havnt lowered switched main gear for lower speeds more torque as the cover wont fit if you do that. THe guy at the local HS has reversed his shocks so they are upside down and has a much larger main gear off the main motor pinon.
This thing is so fun!
more later!
