RE: echo 22.8 cc gas engine
newguy05: You do not need to remove flywheel to place prop on engine. Just add a prop adapter...then prop. In the added photo the part on the crankshaft is the center of the flywheel. I am going to do the 2nd engine with stock flywheel ignition. This one is for Gas/glow or electronic ignition. Capt,n
