RE: Rotary carb question
Try taking the barrel out and then lift the hook on the end of the spring, up out of its slot. Let the spring relax and then cut a slot to in the plastic ridge to match the original shape but in the new relaxed position.you might want to make the location so it just goes to a closed position. This has worked well for me on several rotory carbs.
Motorhd
