RCU Forums - View Single Post - Field box?
Thread: Field box?
Old 03-23-2003 | 06:02 AM
Whirley Bird
Default Re: Great Planes Master Caddy
Originally posted by barzini
I finally decided on a field box.I picked up the prebuilt Great Planes Master Caddy.It's nice, Especially the detachable power unit. The only thing that i had to do was enlarge the opening for the power panel.No big deal. This box should be just fine.
Barzini
Not a bad tote box but the one they sent me had no fuel sealer at all on any part of the inside.
The drawer dividers were not glued to the bottom.
Use some Elmers glue then use a good sealer and let the wood soak it up.
Usually three coats will do and you have a nice gloss.
The white they use on the outside seems to be some sort of epoxy paint.
There is no power meter I know of that will fit the hole.
Seal it good and it will last forever
