RCU Forums - View Single Post - throttle linkage.....what end to use on the carb
Old 08-08-2007 | 07:23 AM
tstotts
Default RE: throttle linkage.....what end to use on the carb
Not having enough room for the travel needed on your throttle is a pretty common problem. Having a metal clevis on a metal throttle arm is a no no. Use a short plastic clevis if you have the room. A good quality ball link is a good choice also.
