RCU Forums - View Single Post - making servo extensions.
Old 08-08-2007 | 07:30 AM
bruce88123
Default RE: making servo extensions.
One of the more important reasons for heat shrinking is to avoid future breakage. The solder tends to "wick" up the wire, this stiffens it. The point where it transitions from stiff to flexible again will be the failure point and requires support (stress/strain relief). The heat shrink will give a semi-flexible transition that will reduce breakage.
