RE: 3w TOC 150 Engine Problem
Thanks guys, I was wondering about the ignition getting hot an possible quitting on me, Currently it is mounted on foam. I will try putting it on stands to get some air running under it, As for the "rain cominfg out the of the exhaust" This was done once to ensure the engine was not running lean, Like I said before if you tried to lean it out it quits. I know the standard settings are around 2 1/4 out for both High n Low for a good starting point.
