RCU Forums - View Single Post - question on servos for a u-can do
Old 08-08-2007 | 07:30 PM
txaggie08's Avatar
txaggie08
Default question on servos for a u-can do
Ok, I'm thinking about picking up a u-can-do 60 to replace the plane I thrashed yesterday trying an outside loop . And yes, I have been flying for a good while etc. etc., and have been on the stick of a U-can-do before .(that way noone has to type up the long standard response, I ask here because this plane is suitable for newer pilots and the questions can't hurt )
My question is this. It calls for one standard high torque on the rudder and two each standard BB on the elevator and ailerons....
Will s3004's work for the elevator and rudder? IT is rated as well as the s3001's the Tower reviews used on the tail, but not quite as tough as the s9001 core-less's used on the ailerons. I also have a CS-70 wich will put out 109 on the rudder at 4.8v.
Will the s3004's and the cs-70 work for this aircraft? I will be running my ST .75 on it, and am not capable of 3-d flying yet, so thats not that big of worry . I'm mainly interested in doing basic stall turns, loops,immelmans, outside loops, rolls, maybe tryin to learn high altitude to hover or do a knife edge.
I can, if necessary go to 6v wich would bump me up to 56oz on the 3004's and 134oz. on the cs-70
