RCU Forums - View Single Post - Radio interference off of a building?
Old 03-13-2003 | 06:47 PM
strato911
Default Radio interference off of a building?
I have read a well documented case where a metal grain silo caused the same problem, so it may not be due to welding. Your radio signal can bounce off the building (like an echo), but it will be delayed. The echo signal will then conflict with the true signal and it will be the same as if another pilot had turned on his radio on your frequency.
