RE: Hinge Tape
If you check with the specialty sailplane suppliers you will find several options. Also, I have used 3M 600 clear tape on sailplanes that flew over 100mph with no problems. Only drawback to 3M 600 is that it needs to be replaced periodically. On the up side, it's cheap.
Good luck,
David Layne
