Prop balancing
Yeah it will add a very slight amount of weight back. Use just enough to re-cover the bare wood, the amount needed is alomst weightless. You can re check it for balance after you do this, but it should still balance.
I'm with minnFlyer on this one...as long as its somewhat close!!!
