RE: Autorotation for Electrics
Hi, thanks for the info. You are right, if my motor is not spinning, I can turn the rotorhead as you say. But it doesn't spin too easily, probably because of the driven tail. The thing is, once I land the heli and put throttle to minimum (engine off) the rotor will spool down to a complete stop in about 3-4 seconds. Is this normal? Doesn't seem like much time to do an auto!
