RCU Forums - View Single Post - difference in +expo and -expo
Old 08-09-2007 | 08:43 PM
Redback's Avatar
Redback
Default RE: difference in +expo and -expo
Usually 20 to 30 percent is a good place to start.
Normally expo would be used on a model with quite control surface deflection to soften response at the mid stick point.
Some caution is needed when using expo for the first time because of the non-linear response, ie the more you move the stick the more responsive it gets. Definitely starting low is a good idea.
Terry
