RCU Forums - View Single Post - O.S. Gurgle
Thread: O.S. Gurgle
Old 08-09-2007 | 10:30 PM
alan0899
Default RE: O.S. Gurgle
G'day Mate,
Sounds like midrange is rich, try pinch test, & set idle mixture, then run up to full power & rise nose of plane, if set properly engine should speed up slightly, if it speeds up a lot, lean out slightly until it speeds up slightly & fly, then try throttle response in midrange, it should be better, also what prop, 11x6 is a good starting point.
