RCU Forums - View Single Post - O.S. Gurgle
Thread: O.S. Gurgle
Old 08-09-2007 | 11:27 PM
mesaflyer
Default RE: O.S. Gurgle
ORIGINAL: ro347
Using a 10x6 prop.
Roland,
Like alan said, try changing the prop. Also, how many tanks of fuel have you ran thru the engine? So far, after about 30 flights, my AX is running real good, but my FXi needed a lot of adjusting after it was broken in. Had to adjust the idle screw in order to make the correct needle valve adjustments. I'm running 10% nitro, 18%oil.
Peter
