RCU Forums - View Single Post - Adding Wieght to Tail
Old 08-10-2007 | 10:08 AM
broke_n_bummin's Avatar
broke_n_bummin
Default RE: Adding Wieght to Tail
You said the manual says the CG should be 4 1/8 from the leading edge. Typically, there should be a range of about 1/2 inch that will work. Was the 4 1/8" supposed to be in the middle of the range?
