Hi!! And welcome to the forums. I too am new to helis and if I make make a suggestion to help you get the answers to your questions. It would be best if you started your own thread simply because not too many people will read this one anymore since it's older. With your own thread, you will have a much better chance of getting your problem solved. That's just alittle bit of freindly advice to help you get the help you need. Unfortunatly, I can't answer that question, because I haven't had that problem....yet, but with all the good people around here, I'm sure there is an answer out there!!(playing theme from the X-Files as I type!!
) Good luck, and again welcome to this mad house!!!!
