RCU Forums - View Single Post - Adding Wieght to Tail
Old 08-10-2007 | 02:06 PM
bbbair
Default RE: Adding Wieght to Tail
ORIGINAL: Bobcat1506
I was balancing it right side up…. the manual shows the plane on the CG machine right side up and the manual says to mark the balance point on the bottom of the wing, not the top. Should I try to balance it upside down?
NO, with the design of that plane I would balance it right side up. Inverted balancing is what you do for low wings.
