RCU Forums - View Single Post - Engine Running problems
Old 08-10-2007 | 05:15 PM
red head
Default RE: Engine Running problems
LEAVE the low speed alone !!! Remove the high speed needle and pump fuel through the carb till it flows out of the high speed valve, then put the needle back in and turn it in until it just touches bottom, now back it out 2 1/2 turns. It should start there then you can adjust it to what you want. ENJOY !!! RED
