RCU Forums - View Single Post - Engine Running problems
Old 08-10-2007 | 07:39 PM
bruce88123
Default RE: Engine Running problems
Find a way to put fuel (under slight pressure) directly into the carb inlet nipple. You should see fuel spraying from the spray bar in the carb when the throttle is wide open WOT. No spray=blockage. Old fuel can congeal almost anywhere.
