RE: Not a good day. Advice?
ALso if your LHS only has blades for the BladeCP, you can use those as replacements until you get some for the Axe. Blade rotors are shorter but they work. You will have to remove part of the cap covering the end of the blade to make them fit in the blade grip. They are a bit shorter than stock but they fly great.
