RCU Forums - View Single Post - Charging questions
Old 08-11-2007 | 02:26 PM
K94max
Default RE: Charging questions
Strat - I am using 11.1v 910 mah. I fly (hover) for about 8 min to 8 1/2 min. Have gotten to where I can keep it in the air most of the time so that there is draw on the battery most of the time. At that, I recharge at the recommend rate for the 11.1 900mah lipo battery and it usually takes 1 hr to 1 1/4 hr on average. If you do not keep it a constant throttle setting (for in air flight) the flight time should be longer. I don't remember if you got the triton jr. but if so, when you hook up the battery and press the start button look in bottom left corner of screen and just as soon as the number appears that is how much you have discharged to. At 8 to 8 1/2 mins mine usually is about 11.3 give or take. I could fly longer times but the battery gets hot as well as motor and I don't want to push my luck on early battery death or motor death for an extra minute or two for flight time let alone possible cutoff due to low voltage.
how long can you fly - if you discharge below 9.6 consistently your pushing it (if I understand what I have read and been told).
