ORIGINAL: goirish
I have checked the fuel lines and no I have not checked the low end setting. Are you talking about the low end idle screw?
The K&B's came with a variety of carbs. Does yours have a K&B carb or a Perry carb? If you can't even set it on the ground the idle mixture must be wrong.
