RCU Forums - View Single Post - Do I need to move on?
Old 08-11-2007 | 06:15 PM
aerowoof
Default RE: Do I need to move on?
there are loops and then there are loooops,
are your loops perfectly round and to you finish at the same altitude as you started or are they egg shaped and you finish lower that at your starting altitude?the first scenario is the correct loop if you can do that then you are ready for other manuvers if you are in the 2nd catagory practice is required,reduce throttle on the down side
