RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 08-11-2007 | 09:05 PM
  #4015
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
ORIGINAL: noguy
OK quick point: Anyone who says the blade cp heli are good for nothing can go fly a kite. This little heli planted the seed in me that has grown into a monster. Well and everyone here has helped create this monster too. And I love it!!! This is what the bcpp has lead to for me....I'm becomming a heli [link=http://www.rcuniverse.com/forum/m_5974113/tm.htm]NUTCASE[/link] and I love it. Still crossing my fingers to win that 600n pro. I will always keep this little bcpp. I love the little guy and wont ever let anyone take it away....
Wheeeeeeeeeeeeee.......bcpp
I gotta admit....I sorta miss mine, but I don't miss working on it. I'm running 2 HBKII's and unless I crash or hit....I seldom wrench on either of them...they just fly. In the blade CP/CPP favor...I can set up a heli perfectly because of the working on my CPP. The HBKII has problems out of the box too. Personally...I think the stock rotor blades are a joke. The stock motor and ESC are junk out of the box too and going brushless is mandantory. The final real defect in the HBKII is the inherient tendency to throw the belt which requires installing a taller brass shim and re-drilling the pin hole on the main shaft higher so the belt/pulley are properly aligned. After you get it properly set up...it works flawlessly. I spend time charging batteries and flying...not figuring out what's wrong. The HBKII electronics are pretty reliable other than some glitching once in a while with the stock radio system just like the Eflite stuff. If nothing else, owning the CP series will make you a good troubleshooter and heli mechanic.
