RCU Forums - View Single Post - Engine Running problems
Old 08-12-2007 | 10:00 AM
Geau4LSU
Default RE: Engine Running problems
Red if have already messed with the low speed. Where should it be set? When I remove the high speed needle, should the fuel flow into the carb or outside the needle arm or both? I removed the entire high speed assembly and blew air thru it. It doesn't seemed stopped up.
